Hello Guest it is November 13, 2026, 08:09:34 PM
Author Topic: Re: Using a PWM controlled laser  (Read 8218 times)
« on: April 01, 2020, 03:27:24 AM »
Good day
I have download the impact and engrave add on for mach 3
I have some questions on how to wire and set up
1.Witch pins do i wire up the laser to
    Do i need to wire the pwm signal to the break out board
    And the enable signal
I require details on how to set up the config in pins and port on mach 3
Because  there is now clear manual on the set up or the wiring of this
Can any body please provide any details on this on how thy set up there laser
I am using a co2 laser
See attach photo of break out board
The manual provide in post #7 has no clear description on wiring or pin config and example will be nice
Thank you in advance
  •  9,377 9,377
« Reply #1 on: April 01, 2020, 04:23:12 AM »
This post details my solution;  https://www.machsupport.com/forum/index.php?topic=12444.msg265104#msg265104
Perhaps other posts in the same thread may be of interest to you.
