Hello Guest it is September 30, 2026, 12:45:32 AM
Author Topic: How to get the last pressed button's oem code?  (Read 19512 times)
Offline sebba
  •  42 42
« on: March 27, 2020, 06:02:46 AM »
Hello,
There is any way to get the last pressed button's code and place it into macro as variable?
For Mach3.
Thank you,
Seb
Offline TPS
  •  2,627 2,627
Re: How to get the last pressed button's oem code?
« Reply #1 on: March 27, 2020, 06:07:21 AM »
no, not realy, but you can set/reset OEMLed's in the button script and read those in an other script. you may also use an
OEMDro and set them in the button script.
f.e:
buttonscript off button1 set OEMDro to 1
buttonscript off button2 set OEMDro to 2
and the other script reads the OEMDro
Offline sebba
  •  42 42
« Reply #2 on: March 27, 2020, 09:42:46 AM »
thanks for your reply
I thought there is some more "elegant" solution  :)
« Reply #3 on: April 08, 2020, 11:58:01 PM »
hi
i am new here
. can any body help me how to download mach3 vb script editor software
Offline sebba
  •  42 42
« Reply #4 on: April 09, 2020, 02:54:43 AM »
install Mach3 and run VB Script Editor from Operator menu
