Hello Guest it is November 23, 2026, 02:05:38 AM
Author Topic: Mach3 - auto tool zero not working with a certain router bit  (Read 9059 times)
« on: March 26, 2020, 07:50:34 AM »
Hey guys, I've been fiddling around with a CNC router for about 3 months now and just stumbled upon a problem.
So every time I try to do auto tool zero with tool number 3 (3mm end mill), it works like a charm. When I try to do it with tool number 4 (6mm ball nose) the machine stops 7-10mm above the plate.
Would love to try your solutions. Cheers.
Re: Mach3 - auto tool zero not working with a certain router bit
« Reply #1 on: March 26, 2020, 08:05:51 AM »
Nevermind, does that with every tool now. Still need help.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: March 26, 2020, 07:38:00 PM »
It could be the G31 command in the macro, it needs more Z movement.
« Reply #3 on: March 27, 2020, 02:39:22 AM »
Yep, Z movement was set to 200, thanks.
