Hello Guest it is October 24, 2026, 11:18:41 PM
Author Topic: Mach 4 Won't Shut Down!  (Read 6341 times)
« on: March 23, 2020, 07:21:53 PM »
Having an unusual problem with Mach 4.  I am running Windows 10 and if I shut down Mach 4, the next time that I start it up again, I get an error message telling me that there is another version of Mach 4 running.  The only way that I can start Mach 4 is if I use Windows Task Manager to end the task.  As long as I use Task Manager to shut down Mach 4, it will start right up next time that I use it and run great.  Anyone have any idea what is going on and how to fix it?
Richard
Offline smurph
  •  1,575 1,575
Re: Mach 4 Won't Shut Down!
« Reply #1 on: March 23, 2020, 11:10:02 PM »
Some plugin is keeping Mach from shutting down.  Copy your profile and launch it.  Then disable each plugin, one by one, until the problem goes away.
Steve
« Reply #2 on: March 25, 2020, 12:26:58 PM »
Steve
Thanks, that makes sense, I'll try that.
Richard
