Hello Guest it is November 22, 2026, 08:03:11 PM
Author Topic: My Probing don't working  (Read 12830 times)
« on: March 20, 2020, 01:34:18 PM »
Hello
I bought a CNC control board from china and configured the Mach3 according to the manual of the board, everything works perfectly, but I'm having problems in the probe. I start the macro and the X axis begins, but when the probe does the grounding the X axis continues to work and force the cutter, what may be wrong ? Below this my setup and the image of the board I'm using.
My Configuration
My CNC Board
 If anyone can help me,Thanks
Offline TPS
  •  2,627 2,627
Re: My Probing don't working
« Reply #1 on: March 20, 2020, 02:05:19 PM »
first off all, go to diagnostic and have a look for the digiitze Signal,
does it come up if you hold your clamp to the cutter?
« Reply #2 on: March 20, 2020, 03:03:04 PM »
Hi, TPS
So, I haven't signal.
Thank You
« Reply #3 on: March 20, 2020, 04:16:40 PM »
Hi, My cnc machining is working, but the probe don't have signal, How could I solve it?
Thank you for help me.
Offline TPS
  •  2,627 2,627
« Reply #4 on: March 21, 2020, 01:59:12 AM »
do you have a link to the Manual of your Controller?
« Reply #5 on: March 21, 2020, 03:10:28 AM »
Hi, I think it will need some power supply, maybe the 24V, you should have it in the board manual ...
Joseph
https://www.buildyourcnc.com/images/RNRInstructionImage22-800.JPG
« Last Edit: March 21, 2020, 03:12:35 AM by pepazhar »
« Reply #6 on: March 21, 2020, 07:36:03 AM »
Hi
Yes, I have the USB Board Documentation and Board Schematic and my Macro.
https://www.buildyourcnc.com/Documents/USB%20Motion%20Card%20STB4100%20Manual.pdf
Board Schematic
My Macro
Code: [Select]
Rem VBScript To center probe inside a pipe
Dist= 20.0 'Maximum detection depth 20.0
ZDist = 4.0 'When finished, put a knife 4.0
If GetOemLed (825) <> 0 Then 'Check the probe if it is disconnected
Code "(Probe plate is grounded, check connection and try again)"
Else
DoSpinStop()
FeedCurrent = GetOemDRO(818) 'Save the feed rate
XCurrent = GetDro(0)
YCurrent = GetDro(1)
ZCurrent = GetDro(2)
Code "G4 P1" 'Pause 1s
Code "F25" 'Adjust the speed more slow
Rem Probe left
XNew = Xcurrent - Dist 'probe 20mm to left
Code "G31 X" &XNew
While IsMoving() 'wait for the move to finish
Wend
XPos1 = GetVar(2000) 'get the probe touch location
Code "G0 X" &XCurrent
While IsMoving ()
Wend
'rapid move back to start point
Rem Probe right
XNew = XCurrent + Dist 'probe 20mm to right
Code "G31 X" &XNew
While IsMoving()
Wend
XPos2 = GetVar(2000)
XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
Code "G0 X" &XCenter
While IsMoving ()
Wend
'rapid move to the x center location
Rem Probe up
YNew = YCurrent + Dist
Code "G31 Y" &YNew
While IsMoving()
Wend
YPos1 = GetVar(2001)
Code "G0 Y" &YCurrent
While IsMoving ()
Wend
Rem Probe down
YNew = YCurrent - Dist
Code "G31 Y" &YNew
While IsMoving()
Wend
YPos2 = GetVar(2001)
YCenter = (YPos1 + YPos2) / 2
Rem move to the center
Code "G0 Y" &YCenter
While IsMoving ()
Wend
Code "F" &FeedCurrent  'restore starting feed rate
ZClear = Zcurrent + ZDist
Code "Z" &ZClear
End If
« Last Edit: March 21, 2020, 07:38:15 AM by Mack3CNC »
« Reply #7 on: March 21, 2020, 07:50:49 AM »
you have to have 24V power, just as I sent the picture, yours is the same, then checked the diagnostics card in Mach to see if the light comes on when touched ..
  •  9,378 9,378
« Reply #8 on: March 21, 2020, 08:33:44 AM »
Hi Mach3CNC,
I have sent you a PM.
