Hello Guest it is November 13, 2026, 05:01:06 PM
Author Topic: running a 3d printer from mach4/pokeys57CNC  (Read 28597 times)
« on: March 20, 2020, 10:44:45 AM »
I have the following equipment ;
Modern PC running Windows 10
licensed copy Mach4
A Pokeys 57CNC
Creatity Ender 5 3d printer w/ single extruder head.
I have spent years learning LUA . Pokeys and the Mach4 system
Would like to use mach4/Pokeys57CNC  on the 3d printer.
What I would 'like' to do is connect and run the steppers and end switch's
directly from the Pokeys 57CNC. That part seems simple.
QUESTIONS ;
How could I  run a extruder step motor from mach4/pokeys. How could the extruder know how much filament to extrude.
How could I control the two heaters (base plate and extruder) from mach4/pokeys. There are several thermistors on the printer to feedback temperatures.
I am hoping if I cannot run it all from MAch4, I could use the Smoothie board for the heaters and extruders and  mach4/pokeys for the Steppers.
Existing control system. The original  board in the printer was replaced with a network smoothie board and Smoothieware software
After much trial and error it works but pain in the  ....
any hints , ideas greatly appreciated.  stay safe.
Re: running a 3d printer from mach4/pokeys57CNC
« Reply #1 on: June 18, 2020, 02:43:07 PM »
Hi Machiner,
what´s about your extruder`? solved or under construction`?
Normaly an extruder is an rotatory axis and you can calculate the length of the filament over the diameter of your extruder weel.
hopfully it helps.
