Hello Guest it is November 22, 2026, 07:43:07 PM
Author Topic: Spindle control  (Read 8315 times)
Spindle control
« on: March 17, 2020, 10:08:22 PM »
I am trying to use a stepper as a spindle, but can not get it to work. Any ideas?
Re: Spindle control
« Reply #1 on: March 19, 2020, 02:26:55 PM »
What are you driving it from?  What do you mean by "it doesn't work"?  Mach assumes that the motor runs at a speed which can be set, for example by smoothing the PWM output to get a voltage for the motor drive.  It does not generate a stream of pulses at a variable frequency to drive a stepper.  IMHO a stepper is a very poor choice for a  spindle drive, why do you want to use one for that purpose?
Re: Spindle control
« Reply #2 on: March 19, 2020, 03:31:14 PM »
its been a whaile since I've used Mach3 but certainly Mach4 has the option of a step/direction spindle, and if memory serves I think
Mach3 does as well.
I do agree with the previous poster, steppers just plain run out of steam the faster they go. A step/direction servo is a good choice though.
I have a 1.8kW 3500rpm 6.2Nm (cont) Allen Bradley AC servo and drive as a spindle motor and it kicks arrsse!
