Hello Guest it is November 23, 2026, 05:06:19 AM
Author Topic: Modifying Buttons in Mach 3,  (Read 19811 times)
« on: March 17, 2020, 06:14:12 AM »
Good Day all,
I am looking for some help in re configuring my mach 3 screen. Currently I have X, Y, Z and A/4. I have an issue with my CNC at this moment and trying to locate the fault.
I have swapped my drive for the A into Z position and want to disable the A/4 from the whole process of Ref all etc. I have turned it off in all tabs of ports and pins Just need to stop it calling it when i hit the ref all.
Thank you kindley
Regards Tom
  •  9,378 9,378
Re: Modifying Buttons in Mach 3,
« Reply #1 on: March 17, 2020, 07:16:03 AM »
Hi Tom,
Download OEM codes from Members Documents here; https://www.machsupport.com/forum/index.php?topic=9312.0
Within Mach3 click;   Operator / Edit Button Script, click on the flashing Ref All button. Change and save the script as required.
« Reply #2 on: March 17, 2020, 08:48:05 AM »
Thank you for your link made a whole lot more sense.
Have a good day :)
