Hello Guest it is November 22, 2026, 09:52:29 AM
Author Topic: Stepper motor speed varriations  (Read 20901 times)
« on: March 04, 2020, 12:00:37 PM »
My stepper motors on the X and Y axis make different sounds and change speeds as I manually move them by using the keyboard.  What might be causing this?  It is a new setup, so I may have some parameters wrong.
Roger
Re: Stepper motor speed varriations
« Reply #1 on: March 04, 2020, 12:21:25 PM »
what happens when you MDI G0 moves on each axis rather than keyboard jog?
« Reply #2 on: March 06, 2020, 05:03:00 PM »
My apologies for the delay.
It seems to do the same thing in either mode.
« Reply #3 on: March 06, 2020, 05:38:27 PM »
OK you need to try some experiments to work out whats happening.
What are your native units? I use metric so I will assume mm units.
In the first instance you need to write and run small Gcode programs to test each axis, firstly at low speeds slowly
increasing to rapid traverses.
For example:
g1 x200 f100
x0
x200
x0
x200
x0
x200
x0
This code should cause the x axis to move back and forth by 200mm at a max of 100mm/min.
Now try the same code but at higher feed speed:
g1 x200 f200
x0
x200
x0
x200
x0
The same motion, back and forth but at 200mm/min.
And again at a higher speed:
g1 x200 f300
x0
x200........etc
Keep repeating the test but with ever increasing feed speed.
I don't know what speed max speed you have tuned your motors for, lets guess at 2000mm/min. Then the following code
tests the x axis at rapid traverse speed:
g0 x200
x0
x200
x0
x200
x0
I am guessing that if you follow this you will find an eventual limit beyond which you get the variations in speed but
below that limit the x axis behaves normally.
Try it and report back.
Offline ZASto
  •  434 434
« Reply #4 on: March 07, 2020, 03:06:21 AM »
Could it be that you have very low acceleration?
My personality is who I am.
« Reply #5 on: March 07, 2020, 11:24:54 AM »
In the interest of full disclosure, I am new at this.  I just finished building this CNC Router and have installed and wired the controller (TB6560T4V1) with a Parallel interface and this controls 4 ea. NEMA 23 steppers (X, Y, Z, and A axis) A being slaved together with the Y axis.  On the Controller board I have the Microstepping (working mode 1/8, dip 3&4 on) Current decay (Slow decay, dip 1&2 off)  Current setting dip T1&2 are off for 100%*2.5A.  That's it for the hardware setup.  Not sure I understand these settings, but if they are incorrect please let me know.  The stepper motors have 24 tooth 3M pulleys operating on a timing belt, for the X & Y axis movement.
Initial setup for Mach 3:  Native Units mm.  Port#1 enabled. Motor outputs X, Y, Z, A enabled.  Step Port and Dir Port all set to 1.  Y axis Dir Low Active green check. Step pin# 2, 4, 6, 8.  Dir Pin # 3, 5, 7, 9.  Input Signals X+- enabled pin 10 both,  Y+- enabled Pin 11,  Z+- enabled pin 12,  EStop enabled pin 13.  Output Signals, Enable1 pin 1 Output #1 pin 14.
Unless there are other parameters to set up, it is on to motor tuning, on which I am a bit confused.  Some help here would be appreciated.
Roger
Offline ZASto
  •  434 434
« Reply #6 on: March 07, 2020, 12:37:59 PM »
Max speed and acceleration are set in Motor tuning.
« Reply #7 on: March 07, 2020, 12:52:54 PM »
How do I determine max speed and acceleration?
« Reply #8 on: March 07, 2020, 01:02:53 PM »
I am a bit confused with the calculation and use of: Micro stepping, Steps per unit, steps per revolution, cycles per revolution, Mach 3 steps per unit, as they should be calculated for my particular unit.
« Reply #9 on: March 07, 2020, 01:03:50 PM »
the 'Setps per Unit' value can be calculated or measured. It is specific to your machine and unless you change your
ballscrew or belt pulleys will stay the same for the life of the machine.
Maximum speed (also called velocity) and maximum acceleration have to be arrived at by experiment. My previous
post outlines the procedure.
What you are trying to do is top establish the capabilities of your steppers/drivers and then set your maximums
WITHIN those capabilities so thy don't lose steps when operating.
