Hello Guest it is October 20, 2026, 03:05:06 PM
Author Topic: How to connect my KX3S to PC via Ethernet?  (Read 7103 times)
« on: February 25, 2020, 02:46:37 PM »
Hi, I have just purchased a KX3S cnc mill but it did not come with any software etc. I know the machine hasnt even done 20 hours and is like new. I have all the tooling, handwheel and 4th axis for it but not software to connect it to the laptop. I have installed Mach 3 but I still cannot get it to communicate. It is has Ethernet connection. I have managed to get the laptop and machine seeing each other (i think) but does anyone have a very step by step instructions on how I can make my machine work? I have been searching for weeks. Please help. Im a complete novice when it comes to the setup. Thank you
Offline TPS
  •  2,627 2,627
Re: How to connect my KX3S to PC via Ethernet?
« Reply #1 on: February 26, 2020, 01:25:22 AM »
have you tryed to contact Sieg? without knowing witch Motion Controller is installed, it will be nearly impossible to find the correct plugin for it.
