Hello Guest it is November 23, 2026, 05:06:12 AM
Author Topic: Tool speed set higher then the motor running speed? Missing steps  (Read 21426 times)
Hi there,
I’m running a desktop windows 7 32. Bit. Multi core processor, stand-alone video card and printer express port card With a LPT port breakout board.
If wondering if I tell my tool to run at 2000 mm/min and in my ports and pins under motor tuning I have the motors speed set to 1998 mm/ minute will this cause miss-Steps every once and a while?
I use Fusion360 to design and make the tool paths gcode. I bumped up my cutting speed from 1900 to 2000 recently. Im missing steps as much as a deviation in one shot of 10mm
Right when my tool path changes from a 3D Adaptive clearing to a 3D ramping tool path.
Glen
Re: Tool speed set higher then the motor running speed? Missing steps
« Reply #1 on: February 24, 2020, 03:47:19 PM »
no, Mach's parallel port will run up to a maximum of 1998mm/min even if the Gcode or MDI calls for faster.
« Reply #2 on: February 24, 2020, 07:13:33 PM »
I was not aware of the printer port having a say in the tools feed rate max?
At a frequency of 25 kHz I would have thought you could tune the motor up to 2400 mm/ min
« Reply #3 on: February 24, 2020, 07:38:21 PM »
 maybe I'm misunderstanding you....are you talking an axis or a spindle?
Axes move at so many mm/min but spindles at so many rpm.
If you have tuned an axis motor to a max of 1998mm/min and your Gcode calls for a G0 of 2500mm/min the axis will travel
at is 'tuned max' namely 1988mm/min
« Reply #4 on: February 24, 2020, 09:11:35 PM »
Feed rate of my axis mm/min for X,Y,Z motor tuning settings
Thanks for the info.
Glen
