Hello Guest it is October 21, 2026, 09:05:00 PM
Author Topic: Motors won't turn in Mach4  (Read 5319 times)
« on: February 21, 2020, 03:31:17 PM »
Im new to all this home CNC stuff... I bought a machine a half a year ago and right now its in the finishing process. And now i need someone smarter than myself  :(
But I have problems configuring the system right. From what i can see I have all connections the right way.
But when i connect all power, the stepper motors won't move. at all... They just stay locked in place.
My parts look a bit like this...
With a ESS smoothstepper, and a BOB, going to the motor drivers.
Haven't hooked all the home and limit switches yet, or even emergency stop.
Since i cant even get this to work, that seems a bit excessive.
So far, i have checked the 24V to be ok and i have fed the 5v rail with 3A (it drops to 4.3-4.4v during power on tho)  but i guess thats normal. I dont get any error messages and the DRO in mach 4 shows movement. The diagnostics tab for the ESS shows the output ports are high when used.
Is there anyway i can measure the signal going from ESS and or smootstepper, driver motor without an oscilloscope?
and is this the only place i need to configure pins ans ports for the motors?
I searched the forum but with no success to this problem, and only a few hits on google, but without any conclusion...
Thanks in advance....
Best regards //Lars
