Hello Guest it is October 22, 2026, 07:08:42 PM
Author Topic: Using Isel CNC Controller C 142-4 with Mach3 ??  (Read 40559 times)
« on: September 19, 2007, 06:42:51 AM »
Hey!
I have a school project to modify a glueing robot to be a wood miller. The glue robot is using Isel's CNC Controller C 142-4 to operate the step motors. I wonder if I can just plug in my laptop with mach3 software to the controller by using RS232-port. Is mach3 able to control the robot  or do I have to use printer port?
Re: Using Isel CNC Controller C 142-4 with Mach3 ??
« Reply #1 on: September 19, 2007, 07:36:53 AM »
You will need to interface the Stepper drives to the P Port and I would recommend getting a break outboard as well.
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: September 19, 2007, 09:54:25 AM »
What breakout board you suggest?
« Reply #3 on: September 19, 2007, 02:42:27 PM »
I just noticed that the Isel C 142-4 controller includes 8 opto-isolated signal input so maybe no need for a breakout board (http://www.iselautomation.de/productdb/download.php?ID=2791). The controller only has an RS 232C port, will this be an problem for using mach3?
« Reply #4 on: September 19, 2007, 09:06:07 PM »
Do you know the pinout for the cable? if it is all step and direction lines you "could" get it to work... BUT for $114.00 each you can get new drives and make the machine a better machine...
PMDX CNC4PC CNCbuilding blocks.... pick any ... have a look on the web
thanks
Brian
www.machsupport.com
« Reply #5 on: February 28, 2017, 12:15:34 PM »
Did you get this to work?
I just bought a cmc with isel 142-4 controller. Would like to use mach4 on it.
Please help :)
« Reply #6 on: August 19, 2017, 12:53:46 PM »
Hi Behnk
I'm just doing this. I've sucsessfully moved the motors with the Pulse step pins on the back of the drivers (just soldered wires on the back of the AZ8061/1 board.
I am using a cheap chineese 5ax Mach3 board ant it runs fine.
I just need to route the limit switches now. It's a simple setup.
https://www.isel.com/en/downloads/dl/file/id/4261/c142_4_1_hardware_manual_complete.pdf
Page 26 hase the driver pins. Just draw wires from the Clock (CLK),Direction and Motor GND to your BOB.
Good Luck
Offline JGN
  •  1 1
« Reply #7 on: August 29, 2022, 10:04:12 AM »
Hi !
Thank you for all the informations. I'm going to retrofit a CNC Charlyrobot to use MACH3.
I'm looking for the appropriate drivers and any useful information as I have few competences in that field.
Johanna.
« Reply #8 on: August 29, 2022, 12:31:54 PM »
Mach3 won't drive a robot
