Hello Guest it is November 22, 2026, 04:13:14 PM
Author Topic: CNC Router servo drive failiure  (Read 7184 times)
« on: February 16, 2020, 03:37:15 PM »
Initially the z axis servo drive would just randomly stop working and wouldn't turn on until i shut the machine down and wait awhile.
That used to be the main issue.
I then foolishly switched z axis servo drive in place of a y axis one and thats when the whole machine basically won't turn on anymore (even after switching them back in their original places).
When i hit restart button inside of Mach3 none of the drivers activate from sleep to run mode. You only hear a relay like on the video and drivers stay in sleep mode and you can only see bb on display the whole time.
Do you have any tips on what i can do to get the machine up and running again? Thanks.
Video: https://www.youtube.com/watch?v=NnfKSddDbdM
Offline TPS
  •  2,627 2,627
Re: CNC Router servo drive failiure
« Reply #1 on: February 17, 2020, 12:59:37 AM »
without any knowledge about your wiring it is very hard to help, but there should be a enable Input on the Motor Driver.
you will have to follow the wiring of this Input witch is probably switched by a relay for all three Drivers.
