Hello Guest it is November 22, 2026, 04:00:50 PM
Author Topic: z axis proximity sensor show like there is contact  (Read 7625 times)
« on: February 15, 2020, 01:49:03 PM »
My z axis proximity sensor is lit up in the diagnostics page. Does this me the sensor has gone bad. I cant Ref all home. X and Y will ref out but z will not move. I can jog it manually so I am thinking the sensor has gone bad. any ideas.
M3Home Staying on
« Reply #1 on: February 16, 2020, 01:03:42 PM »
I have a cncrouterparts desktop Pro with Proximity Sensors. M3Home is staying lit on the diagnostic screen. I switched out the sensor with another one and still the same. I disconnected the sensor altogether and still lit. I can not ref all home. Shouldn't the M3home go out if I disconnected the sensor altogether? I am stumped here, any help would be appreciated.
Offline TPS
  •  2,627 2,627
Re: z axis proximity sensor show like there is contact
« Reply #2 on: February 17, 2020, 01:03:02 AM »
---Shouldn't the M3home go out if I disconnected the sensor altogether?
this is depending on your wiring and on the configuration of the Inputs.
maybe a lose/broken is your Problem, but knowing nothing about your
wiring/confiuration makes it hard to help.
