Hello
Guest
it is
October 22, 2026, 08:41:13 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Mach4 Parallel Port Axis Setup
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach4 Parallel Port Axis Setup (Read 11198 times)
somebody15
5
on:
February 10, 2020, 06:46:18 AM »
Hi there,
I'm new to the CNC world and have been trying to setup a machine with mach4. I was able to set it up with mach3 and everything seemed to work fine, so I bought Darwin to try mach4.
The problem I'm having at the moment is that I can't get all axes to run at the same time. I have a direction pin for x as 7, and step pin for y is also 7. For some reason this worked in mach3 but Darwin doesn't seem to like this. Any help is much appreciated.
Aaron
Logged
Tweakie.CNC
9,374
Super Kitty
Re: Mach4 Parallel Port Axis Setup
Reply #1 on:
February 10, 2020, 06:55:10 AM »
Hi Aaron,
You need to be using a different pin number for each axis step / direction function.
Logged
somebody15
5
Reply #2 on:
February 10, 2020, 06:57:31 AM »
Thanks Tweakie,
I've just been cycling through different combinations of pins to see what works,
do you have a better way of finding the correct combination?
Aaron
Logged
Tweakie.CNC
9,374
Super Kitty
Reply #3 on:
February 10, 2020, 07:15:15 AM »
Hi Aaron,
Which machine controller are you using ?
or
how are you connecting your stepper's or servo's ?
Logged
somebody15
5
Reply #4 on:
February 10, 2020, 07:31:07 AM »
Tweakie,
I'm using the TB6560 CNC Stepper Motor Driver Board Controller.
The machine was wired up by someone else so I'm not sure exactly how they're connected,
but it looks like there are 4 wires from the BOB to the stepper motors.
I did find an old package with suggested pin layouts, but those didn't seem to work.
Sorry for not being able to give better information.
Aaron
Logged
Tweakie.CNC
9,374
Super Kitty
Reply #5 on:
February 10, 2020, 08:54:14 AM »
Hi Aaron,
There are several different types of those TB6560 boards perhaps attach a photo of your board so it can be identified. What Port and Pin configuration are you currently trying ?
Logged
somebody15
5
Reply #6 on:
February 10, 2020, 09:26:15 AM »
Hi Tweakie,
I've attached a picture below, hopefully you can see it.
That config that worked in mach3 that I'm trying now is (dir, step) x-(7,1) y-(3,7), z-(4,5).
Thanks again,
Aaron
Logged
Tweakie.CNC
9,374
Super Kitty
Reply #7 on:
February 11, 2020, 12:11:54 AM »
Hi Aaron,
Can you try again with the picture
https://www.machsupport.com/forum/index.php?topic=24585.0
Logged
Tweakie.CNC
9,374
Super Kitty
Reply #8 on:
February 11, 2020, 12:59:11 AM »
Hi Aaron,
There are a number of different variants of this board but if your looks similar to this one then the common pin configuration is…
X Step 1
X Dir 7
Y Step 8
Y Dir 3
Z Step 5
Z Dir 4
X Enable 14
Y Enable 2
Z Enable 6
Hope this helps.
Last Edit: February 11, 2020, 02:34:08 AM by Tweakie.CNC
Logged
somebody15
5
Reply #9 on:
February 11, 2020, 06:38:01 AM »
Hi Tweakie,
Here's the new picture.
I tried out those settings and they don't seem to work. I went back to mach3 to try there, but it also didn't seem to work there when
I switched the y step to an 8 (from 7).
I have the enable pins exactly the same in mach3 so that's promising, but I wasn't able to find where to use the Enable pins in mach4 which may add to the problem. If you
could let me know where that setting is, that would be great
Do you think it could be bad wiring or maybe something else that I've configured incorrectly?
Thanks for your help!
Aaron
Logged
Print
Pages:
1
Go Up
« previous
next »
