Hello Guest it is November 13, 2026, 10:45:46 AM
Author Topic: last used screen not reloading at startup  (Read 9193 times)
« on: February 07, 2020, 08:50:29 AM »
Hello Chaps,
I have a screen called "fredlath" which is the screen i would like Mach3 to load automatically at startup.
in fact when mach starts up it loads a screen called "fredslathe" which is incorrect - then i have to agree to terms of usage each time.
I have tried deleting "fredslathe.xml" from c:\mach3  but it still finds it somewhere and loads it. thereafter it is in c:\mach3 again.
It never used to do this but now it is a nuisance.
please give me advice how to get it to load the correct screen at startup.
many thanks
fred evans
  •  9,377 9,377
Re: last used screen not reloading at startup
« Reply #1 on: February 08, 2020, 12:21:35 AM »
Hi Fred,
Within Mach3 select View / Load Screens then select the screen .set of your choice.
Close Mach3.
Next time Mach3 is run it will show the screen you have chosen.
« Reply #2 on: February 08, 2020, 08:37:41 AM »
hello tweakie, thanks for responding.
yes that is how it used to work- but now it is not doing that.
(I just went through to the shop and tried it again?)
any other suggestions
regards
fred
  •  9,377 9,377
« Reply #3 on: February 08, 2020, 09:11:58 AM »
Hi Fred,
It works that way for me so maybe something has happened to your Mach3 installation.
The only other thing I can suggest is to re-load Mach3 over the top of your existing installation and see if that corrects the problem (make a secure backup of your existing Mach3 folder first).
« Reply #4 on: February 08, 2020, 09:31:15 AM »
thanks tweakie, i will try that and then report back
regards fred
