Hello Guest it is October 24, 2026, 12:46:03 PM
Author Topic: CSLab CSMIO input problem  (Read 26268 times)
« on: February 04, 2020, 09:52:56 AM »
I have problem with inputs on CSMIO/ip-s module.  Problem is that from time to time it doesn't get input. LED on CSMIO controller comes on, but if we look the same time on Mach3 plugin control corresponding input led doesn't come on. So when program wait for dedicated input it doesn't get it.  In my situation this is when machine waits from Bar feeder Start signal, that it could start cycle again. Because of that machine is stalling all the time.
I try on other inputs, negative and positive triggering.... always the same result. It can do 10 cycles or just one or two, before it stops, and like this all day long...
I kindly ask for any inputs, coz I'm out of idea what else to do.
Whole retrofit end up perfectly now only this input problem prevent machine from running.
Thank you
Gasper
This thread also refers;  https://www.machsupport.com/forum/index.php?topic=42445.msg276042#msg276042
« Last Edit: February 05, 2020, 12:17:29 AM by Tweakie.CNC »
Offline TPS
  •  2,627 2,627
Re: CSLab CSMIO input problem
« Reply #1 on: February 05, 2020, 12:49:42 AM »
BTW. witch Version of Mach3 are you running?
« Reply #2 on: February 05, 2020, 01:04:10 AM »
I'm running 3.043.066 version
Offline TPS
  •  2,627 2,627
« Reply #3 on: February 05, 2020, 01:11:49 AM »
try to run 062 for example from here:
https://warp9td.com/files/Software/Mach3/Mach3Version3.043_2018.exe
i run 043.022 because it was recomended by CSLAB.
« Reply #4 on: February 05, 2020, 01:15:07 AM »
I'll test it today and let you know result.
Thank you
« Reply #5 on: February 11, 2020, 05:09:40 AM »
All I can say is THANK YOU, THANK YOU, THANK YOU!
I installed 062 Mach version, and machine is working 6 hour now without stopping. Before it would stop 100 times at least.
I wills till have some question how to setup servo driven live tools in mach, but I'll leave it run like this some time, and then try to make live tools work.
Thank you again
Best regards
Gasper
