Hello Guest it is November 03, 2026, 07:31:06 AM
Author Topic: mdi of feedrate and tool diameter etc. versus g-code command parameters P,F etc.  (Read 19098 times)
There are mdi ( manual data input boxes) in Mach3 you can enter tool diameter,feed rate etc. in.
The same parameters might be defined by g-code commands.
Which way "wins" when both ways are defined at the same time?
( Are there other parameters than diameter and feed rate and which way "wins" with them?)
