Hello Guest it is November 10, 2026, 02:23:49 AM
Author Topic: 2nd Parallel port card - Outputs....  (Read 9681 times)
Offline Tarak
  •  229 229
« on: September 18, 2007, 05:28:11 AM »
Hey guys, another basic one for you, I've looked everywhere.
I know for 1 parallel port the outputs are controlled like this:
ActivateSignal(Output1)
DeactivateSignal(Output1)
But what commands do you use for a 2nd parallel port to use the outputs.
hhmmmmmmmmmmmm
Re: 2nd Parallel port card - Outputs....
« Reply #1 on: September 18, 2007, 05:36:03 AM »
I'm not sure about this but, your not calling a pin number, your calling an output. Should be the same for the second port I think. What is it labbled as in ports and pins, outputs?
Offline Tarak
  •  229 229
« Reply #2 on: September 18, 2007, 06:05:23 AM »
Thanks Brett, now that I've looked properly.....That was a really DUMB question..................Ha...........
« Reply #3 on: September 18, 2007, 02:46:51 PM »
NP Darc, we all do it at times. I like to call it tunnel vision.  :)
