Hello Guest it is October 22, 2026, 06:45:27 PM
Author Topic: movement very slow and also there other instance of mach on background  (Read 13434 times)
hi
i have very strange behavior on new machine that i never mat on mach system
when we turn on mach we make homing ,then when we try move by jog or run any program all movement very very slow
we need turn off mach restart then its back as normal
but before we try turn on again mach there already one instance of mach that already run ,and we must go in task manager and close it
sure when we close mach we close it as must with confirm not only turn off pc
is anyone have like this?
Re: movement very slow and also there other instance of mach on background
« Reply #1 on: January 30, 2020, 02:34:37 AM »
yes I have had instances where I have accidentally caused a fault with Mach that requires I shut it down. While some
parts of Mach do shut down, other parts do not, and thereafter it necessary to use Task Manager to shut it down.
The issue is what is causing Mach to fail/run slow in the first place? If you prevent that from happening then the restart
problem ever arises.
My understanding is that if a fault occurs in Machs core, something like an infinite loop, then the GUI will shut down but not
the core.
« Reply #2 on: January 30, 2020, 03:07:12 AM »
thanks craig
but do you have ide why its happened?or how solve
its only in 1 or 2 machines happened not all
and the pc is dell new i3 ssd windows 10 64 bit , not some cheap pc
« Reply #3 on: January 30, 2020, 04:00:47 AM »
the only common theme that ties those occasions together was that I was scripting Lua code, I guessed that I had caused a compilation
fault from which the compiler could not extract itself.
I have been using Mach a lot lately but have not be writing any code and no faults.
« Reply #4 on: January 30, 2020, 05:47:39 AM »
about speed that it run very very slow do you have any ide?
« Reply #5 on: January 30, 2020, 11:58:55 AM »
i dont think its lua problem ,because after that problem happened  ,restart the computer solve it ,so if lua ....
« Reply #6 on: January 30, 2020, 12:20:52 PM »
No, sorry I don't.
I think you are correct, a Lua coding fault would be persistent. None the less you have a fault that is hanging up
Machs core (my guess). There is to my knowledge no way to monitor Machs core ad/or selectively kill processes.
« Reply #7 on: January 30, 2020, 12:25:40 PM »
and because the second instance its run very slow?
« Reply #8 on: January 30, 2020, 05:23:35 PM »
To my knowledge Mach WILL NOT OPEN if  there is ALREADY a current instance running.
« Reply #9 on: January 31, 2020, 02:24:00 AM »
thanks craig
is there some one from mach  here can explain why this happened and how should solve?
