Hello Guest it is November 13, 2026, 09:51:43 PM
Author Topic: I can Jog Fine but everything stutters when running GCode or even calibrating.  (Read 32027 times)
Hey there , so was it the ESS or the driver ? Did you try running your setup without ESS?
Good day,  It was the motor driver.  I still used the ESS when testing the new motor driver.  I'm not sure if it is still necessary to use it, however I have it so I might as well.  I wish I had taken a video of the different ways the motors ran with out the ESS and with it, then with the old motor driver and the new motor driver.  I know it would have helped me to see something like that on YouTube because I thought the motors were running smooth after installing the ESS but now after seeing how they run with the new motor drivers I know they were not running correctly before.
Hope this answers you question.  Let me know if you need anything else.
Thank you in advance.
