Hello Guest it is November 13, 2026, 10:02:15 AM
Author Topic: mach3 lathe teach  (Read 12258 times)
mach3 lathe teach
« on: January 26, 2020, 08:15:38 AM »
Hello Chaps
I am using mach3 lathe using the 1024.lset screen
How can I implement the "teach" mode ?
what does it call the "taught" file
and where is the file kept ?
many thanks
fred evans
  •  9,377 9,377
Re: mach3 lathe teach
« Reply #1 on: January 26, 2020, 09:18:07 AM »
Hi fred,
For Mill the teach file is stored;  C:/Mach3/GCode/MDITeach.tap  I assume Turn is the same. If your Turn MDI screen does not have the Teach buttons then you could use a screen editor to add them.
« Reply #2 on: January 26, 2020, 12:06:22 PM »
thanks tweakie-
regards
fred
« Reply #3 on: February 05, 2020, 08:53:56 AM »
Tweakie- thanks i have found the teach files and have run them from the teach button on a mill screen.
It works like a charm except that the mill doesnt have a diameter/radius function.
So I would like to add the teach button to my lathe screen .
Please tell me how to do this . If you would kindly point me to the instruction manual which explains how to do it- I will bu....er around and learn it the hard way. It is probably the best way to learn it and I will use the
knowledge gained to add other buttons as needed
regards fred
  •  9,377 9,377
« Reply #4 on: February 06, 2020, 12:47:27 AM »
Hi Fred,
There is a lot of learning to do but it is not complicated stuff and can be fun.
Download the document;  https://www.machsupport.com/wp-content/uploads/2013/02/Mach2_6.11_Custom.pdf
Section 3 explains how to use a Screen Designer.
Load your lathe screen and add the 2 buttons (Teach ON / Teach OFF  - both would be Execute VB Script buttons). The VB Script for the buttons would be as follows;
For the ON button;
OpenTeachFile”MDITeach.tap”
For the OFF button;
CloseTeachFile
Save your changes and that’s about it.
Hope this helps,
« Reply #5 on: February 06, 2020, 12:53:03 AM »
thanks Tweakie- looks like my weekend project!!
regards
fred
