Hello Guest it is October 23, 2026, 01:36:18 AM
Author Topic: Mach4 with warp9 ess tool change issue  (Read 6537 times)
« on: January 25, 2020, 09:37:27 AM »
Hi all,
i recently changed my control board to an ESS and since then ive noticed that when the machine gets a tool change request, it pops up a message saying tool change then it waits a few seconds then just starts without me pressing any buttons.
the m6 script looks normal.
any ideas what this could be?
thanks Raptor
Re: Mach4 with warp9 ess tool change issue
« Reply #1 on: January 25, 2020, 12:29:17 PM »
could it be that Mach thinks that the tool in place is actually the same as the tool required, ie it
'Has Nothing To Do' and just carries on?
« Reply #2 on: January 26, 2020, 06:44:44 PM »
thanks for your reply,
i don't think its that. i tested it with the "simulated output" driver with a different profile and it worked as expected.
i have attached the gcode i am using.
« Reply #3 on: February 05, 2020, 11:56:51 AM »
My Mach 4 just starting doing the same thing, g code looks normal. Spindle will pause m5 , next line is T1 M6 then starts back up and continues with no input from me
