Hello
Guest
it is
November 20, 2026, 02:56:29 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Machine does not respond when I hit "Go Home"
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Machine does not respond when I hit "Go Home" (Read 5551 times)
ljthomps
1
on:
January 21, 2020, 01:48:20 PM »
I believe this is a common issue but I have not found the answer to fix it. When I press "Go Home" my machine does not move. I can manually jog to home position just fine.
Logged
mark4
167
Re: Machine does not respond when I hit "Go Home"
Reply #1 on:
January 21, 2020, 10:09:39 PM »
Hello
Have you looked at the history bar across the bottom of the screen. It likely will tell you why it wont go home. Have you homed the machine first?
Logged
Print
Pages:
1
Go Up
« previous
next »
