Hello Guest it is October 24, 2026, 06:22:08 PM
Author Topic: Mach4 Plasma move Z+ after cut  (Read 5490 times)
Offline isn
  •  4 4
« on: January 20, 2020, 12:26:33 AM »
Hello,
Is there a possibility that the Z axis moves up to a certain value after cutting a contour (eg + 50mm). To be at a sufficient distance from the sheet metal so as not to get caught anywhere. Could you program that into the M5 macro and if so how?
Thank you so much
Re: Mach4 Plasma move Z+ after cut
« Reply #1 on: June 07, 2020, 01:06:40 AM »
Yes, you can do it by adding some lines of G-code in the M5 marco or whatever macro you use to turn off your torch. I doo this in Mach3 some time before and I think it works too in Mach4.
Simply add a g-code line to tell Z rise some units, for example 100mm or whatever you want. You can create a new DRO for this propuse too for make quick changes on the fly.
Hope this helps.
