Hello Guest it is October 30, 2026, 07:25:15 PM
Author Topic: Plasma ScreenSet  (Read 26547 times)
Plasma ScreenSet
« on: January 18, 2020, 05:41:44 PM »
Hi All,
I have been working on a plasma screenset for Mach3 and here is what I came up with.
The biggest thing I wanted was a simple screen with a large tool path display area.
This is totally customized for my setup, so your mileage may vary  :) My monitor uses a screen resolution of 1920x1080 and I have disabled Auto Screen Enlarge in Mach3
The Park button is used to move my machine to its max + travel (Home is the max - travel) the button just "parks" the machine at the max + position. if you would like to use it you would need to set G59 to your max + position & set the button to use the following script:
Code ("G59 G0 X0 Y0 Z0")
While IsMoving()
Wend
Code ("G54")
The SawCut button doesn't work yet ignore it for now
Here is an image of the screenset:
  •  9,375 9,375
Re: Plasma ScreenSet
« Reply #1 on: January 19, 2020, 12:52:29 AM »
Excellent work fablabracing, thank you for sharing your plasma screen set.
