Hello Guest it is September 29, 2026, 10:47:19 PM
Author Topic: mach 4 machine coordinates not showing  (Read 5893 times)
« on: January 17, 2020, 11:29:26 PM »
hi
so for some reason when i move my machine around via jogging none of the coordinates change  all they do is flash and switch between positive and negative and might jump to like 0.003mm and thats it, im using a galil 4060 and arunning the latest plugin
thanks for your help
Offline smurph
  •  1,575 1,575
Re: mach 4 machine coordinates not showing
« Reply #1 on: January 19, 2020, 05:52:36 PM »
It sounds like you need to install Galil's latest GDK.  Make sure GCAPS is running.
« Reply #2 on: January 19, 2020, 11:37:50 PM »
hi
so i install the GDK only a few weeks ago but im not sure about gcaps as how do i tell if its working correctly as im not finding much information on it
