Hello Guest it is November 12, 2026, 07:26:57 AM
Author Topic: Spindle startup from mach3 trigger reset button  (Read 7953 times)
« on: January 16, 2020, 09:52:54 AM »
I am using windows 10  PMDX 126 and PMDX 107   ess smooth stepper  Huanyang vfd
Every time I start the spindle in mach3 The reset button  go to fault.
My spindle is grounded and I am using shielded cable that is grounded on one side by VFD.
Re: Spindle startup from mach3 trigger reset button
« Reply #1 on: January 24, 2020, 09:26:22 PM »
Are you using limit switches? if so are the limit switch wires shielded? I had this same problem, replaced the limit switch wires with shielded wires and haven't had the issue since
« Reply #2 on: January 24, 2020, 09:49:59 PM »
VFD's are very VERY electrically noisy.
I would suggest as a minimum add a beefy line input filter OR if you want real EMI control......a line reactor.
For example a line filter:
https://nz.element14.com/schaffner/fn2020-20-06/filter-20a-chassis/dp/1191370
And a line reactor, this one is new but they can be had cheaper on eBay:
https://nz.element14.com/block/lr3-48-5-10/line-reactor-3-ph-3-68mh-10a-480vac/dp/2751053
Note these go on the AC line side of the VFD, DO NOT put a filter between the VFD and motor UNLESS the manufacturer
specifically provides for it.
