Hello Guest it is November 10, 2026, 02:25:30 AM
Author Topic: post processor modification  (Read 19326 times)
« on: January 13, 2020, 04:38:11 AM »
good morning
I would like to insert in the gcode (saved by artcam) the date of creation of the file, example:
(FILE = clock)
date <--------------------------------------------
(MATERIAL MEASUREMENT) (X = 310.000, Y = 380.000, Z = 10.400)
  (3,000 mm Flat tool diam.)
G90
G49
M3 S15000
G0 X-1.097 Y-10.347 Z3.000
G1 Z-0.936 F1140
I do not know if it is feasible, I ask for help from those who know more than me
the post processor that I use is the following:
; Fanuc G - Code 4-Axis rotary post processor
; Linear Y Axis is wrapped onto A rotary axis
; History
; Who When     What
; TM  04/07/95 Written
; BEM 06/08/96 Modified for Rotary Axis support
; BEM 19/06/00 Fixed
; BEM 03/02/00 Added description
; JVG 27/10/03 Modified for Mach2 controller, Wolverine3 or Elite6 machines
; JVG 12/12/03 Modified for Mach2 3axis machining
; JVG Feb 23 05 Small modifications with Bill P
DESCRIPTION = "Mach2 mm(*.txt)"
FILE_EXTENSION = "txt"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START     = 0
LINE_NUM_INCREMENT = 1
LINE_NUM_MAXIMUM   = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.0]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|Y|1.3]
FORMAT = [Z|#|Z|1.3]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|Y|1.3]
FORMAT = [ZH|@|Z|1.3]
; Set up program header
START = "(FILE=[FILENAME])"
START = "(MISURA MATERIALE) (X=[XSIZE], Y=[YSIZE], Z=[ZMATERIAL])"
START = " ([TOOLDESC])"
START = "%"
START = "G90"
;START = "G21"
; G20 = Use MM as unit value
START = "G49"
;START = "M6 T1"
; M6T1 = tool change via macros (commented out)
START = "M3 "
;START = "M7"
; M7 = turn misting coolant on (commented out)
; Program moves
FIRST_RAPID_RATE_MOVE  = "G0 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE   = "G1 [X] [Y] [Z] [F]"
FEED_RATE_MOVE         = "[X] [Y] [Z]"
; End of file
END = "G0[ZH]"
END = "[XH][YH]"
END = "M05"
END = "M30"
END = "%"
  I sincerely thank those who can help me
regards
Re: post processor modification
« Reply #1 on: January 15, 2020, 07:48:05 PM »
Have you tried to look at a different post that has this option? I know the post processor in mastercam x4 - 2019 have this in the post and it is done by inserting it under the file name and material type in the same way the file name and material type is posted
Cadcam Man
« Reply #2 on: January 15, 2020, 08:02:43 PM »
This is how mastercam placed the time and date in the post processor
Cadcam Man
