Hello Guest it is November 07, 2026, 10:40:03 AM
Author Topic: LazyCam 2.05 Latest 09 16 07  (Read 11249 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« on: September 16, 2007, 05:44:55 PM »
Hi, Art & Brian
Arc's are still having problems, In the view below.
After re-organizing chains, Rapids in lines seem fine.
In Arc's thy don't change properly and if you move the start point outside the limits box thy turn into circles.
Has been this way for a long time, Posted this several times.
Thanks, Chip
« Last Edit: September 16, 2007, 05:55:18 PM by afn09556 »
Offline Chip
  •  2,055 2,055
Re: LazyCam 2.05 Latest 09 16 07
« Reply #1 on: September 17, 2007, 12:01:06 AM »
Hi, Art & Brian
Ver. 2.47 seems to have fixed the start points / end points, extra rapids being left in.
Edit 09 17 07 Problem returns --------------------------------
The start points with Arc's outside the limits box still turn into circles though.
Thanks, Chip
« Last Edit: September 17, 2007, 06:47:42 PM by afn09556 »
« Reply #2 on: September 17, 2007, 10:11:47 AM »
Chip if you could please upload the DXF that you are playing with and the Lcam project file just before you tell it to clean.
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #3 on: September 17, 2007, 05:12:45 PM »
Hi, Brian
The DXF is in between the two pictures above, Hears the LCAM file
Thanks, Chip
« Last Edit: September 17, 2007, 05:17:40 PM by afn09556 »
« Reply #4 on: September 18, 2007, 09:25:09 PM »
Cool as soon as I get working on Lcam again I will see if I can get that all fixed for you :)
Thanks for the file
Brian
www.machsupport.com
