Hello Guest it is November 13, 2026, 09:47:09 AM
Author Topic: Link script to m8 and m9 command  (Read 10041 times)
« on: January 10, 2020, 08:02:51 PM »
I have create a m1000 and m1001 command to send http command to a smart switch for my dust collector. Everything work good but i will like to use the flood command so i was thinking to add m8 and m9 to the macro folder with my script but it does not work, what could i do to trigger m1000 when m8 is activate and m9 to m1001 when it desactivate.
Offline TPS
  •  2,627 2,627
Re: Link script to m8 and m9 command
« Reply #1 on: January 11, 2020, 10:17:37 AM »
you can not "customize" M8/M9 macro, but
you can use macropump and GETOEMDRO(13) (Floot ON) to send your http commands.
« Reply #2 on: January 11, 2020, 06:25:27 PM »
in Mach4 you can overwrite an existing m8/m9 with your own version, but not in Mach3.
« Reply #3 on: January 12, 2020, 01:52:55 PM »
I came with this code for the macro pump:
Code: [Select]
Dust_status = GetOEMLed(13)
Dust_Var = GetVar(500)
If Dust_status = -1 Then
If Dust_Var = 0 Then
message "Dust collector change to ON"
SetVar(500, 1)
Else
message "No change"
End If
End If
If Dust_status = 0 Then
If Dust_Var = 1 Then
message "Dust collector change to OFF"
SetVar(500, 0)
Else
message "No change"
End If
End If
Now how from the macropump i could execute the m1000 and m1001 command
Offline TPS
  •  2,627 2,627
« Reply #4 on: January 13, 2020, 07:27:20 AM »
do not call a macro from a macro, yust copy yout code from M1000/M1001 into macropump.
