Hello Guest it is November 13, 2026, 12:46:28 PM
Author Topic: 3 axis lathe Mach3 tool charger Quicktech  (Read 29838 times)
Offline TPS
  •  2,627 2,627
Re: 3 axis lathe Mach3 tool charger Quicktech
« Reply #20 on: January 16, 2020, 07:27:36 AM »
if you use
Code: [Select]
  Code "G0 G53 Y"&toolpos1 'move Y-axis
insted of your code and you can enter numbers directly to dro 66.123 will be 66.123 in real
if you want an Offset to 66 use
Code: [Select]
  temp = 66 + toolpos1
  Code "G0 G53 Y"&temp 'move Y-axis
