Hello Guest it is November 13, 2026, 09:44:28 AM
Author Topic: 3 axis lathe Mach3 tool charger Quicktech  (Read 29831 times)
Re: 3 axis lathe Mach3 tool charger Quicktech
« Reply #10 on: January 10, 2020, 06:59:39 AM »
It will be always used as rear post.
If I recall the rear tool post uses G55 Work offsets  for the tools offsets.
So be carefull with your work offsets.
« Reply #11 on: January 10, 2020, 07:07:28 AM »
Remember also that the Lathe tool table is in terms of radii. Machine Coordinates are in radii.
You need to define what lathe mode you want use.
FWIW,
« Reply #12 on: January 10, 2020, 10:40:00 AM »
I manage to get macro work, so I can chose all tools now. But when a chose any toll lat say T0202, machine only move for X,Y,Z written in M6 macro, it doesn't move for offsets I put in tool table. In screen I see requested tool and offset are shown in DRO for requested tool, but machine don't move for offsets.
Offline TPS
  •  2,627 2,627
« Reply #13 on: January 10, 2020, 10:59:19 AM »
the X,Z Offset will be captured by the next move after toolchange, the toolchange itselve will only "correct" the DRO's/coordinates (for this axis).
« Last Edit: January 10, 2020, 11:03:18 AM by TPS »
« Reply #14 on: January 14, 2020, 07:17:28 AM »
but then I have found this topics, and here is also Yaxis lathe.
http://www.machsupport.com/forum/index.php?topic=21851.0
So Can and If yes, how to use this M6 macro to work with my machine.
i think this macro's are a good base to start with.
you will have to design a custom screenpage where you can set your y-axis values.
X and Z Offsets will be covered by Standard tooltable.
in this example M6Start macro toolpositions are stored in OEMDRo's
Code: [Select]
toolpos1 = GetOemdro(1001)
toolpos2 = GetOemdro(1002)
and the it drives the y-axis to the defined value for each tool in machine coords
Code: [Select]
If (toolnew = 1)then
   Call Code("G0 G53 X105 Y4.5"&(toolpos1))
   While ismoving()
      Sleep 100
   Wend
End If
it also moves the X and Z axis to a tool Change position
Code: [Select]
i personaly would do this in two step's, first move X and Z out the collision aeria and then move Y,
or maybe in three step's      1.X 2.Z 3.Y or 1.Z 2.X 3.Y to make sure the is no collision possible.
I would really like to make script in 3 steps  1.X 2.Z 3.Y.
I kindly ask you if you could make quick look how should script look like, only for one tool, I will than modify myself for other tools.
I need to get modified this part:
   While ismoving()
      Sleep 100
   Wend
End If
Thank you
Offline TPS
  •  2,627 2,627
« Reply #15 on: January 14, 2020, 08:24:15 AM »
Code: [Select]
   Code "G0 G53 X105" 'move X-axis
   While ismoving()
      Sleep 100
   Wend
   Code "G0 G53 Y"&toolpos1 'move Y-axis
   While ismoving()
      Sleep 100
   Wend
   Code "G0 G53 Z105" 'move Z-axis
   While ismoving()
      Sleep 100
   Wend
End If
you have to replace the 105 with your machine coords you whant to use!!!!!!!!!
« Reply #16 on: January 14, 2020, 09:27:09 AM »
Code: [Select]
   While ismoving()
      Sleep 100
   Wend
   While ismoving()
      Sleep 100
   Wend
   While ismoving()
      Sleep 100
   Wend
End If
Great thank you so much
« Reply #17 on: January 15, 2020, 07:14:29 AM »
Can someone please explain me what is mean "&toolpos1  coz I have problems with Y height. Sometimes it goes to much up, and for tool 3 it goes all the way to the limit switch. If I delete &toolpos1 for all tools in m6start macro, then are all on the right position.  So where is the catch?
Thank you
Offline TPS
  •  2,627 2,627
« Reply #18 on: January 15, 2020, 07:21:42 AM »
toolpos1 to toolposx are coming from OEMDro's at beginning of code
Code: [Select]
so you have to create a custom Screen, where you can set the Dro's corresponding to your particular tool.
this line of code
Code: [Select]
Code "G0 G53 Y" & toolpos1 'move Y-axis
is only the combination of fix code, in this case "G0 G53 Y" added by the "&" and value of variable toolpos1
let's value of toolpos1 = 1234 the excecuted code would be
G0 G53 Y1234
maybe you can post your actual code.
« Last Edit: January 15, 2020, 07:24:46 AM by TPS »
« Reply #19 on: January 16, 2020, 06:17:29 AM »
Thanks to you guys, i have manage to setup tool change perfectly.
I would just like to make minor change in m6start macro, but I'm not sure if its possible.
This is tool1 :
If (toolnew = 1)Then
   Code "G0 G53 X38" 'move X-axis
   While ismoving()
      Sleep 100
   Wend
   Code "G0 G53 Z-113" 'move Z-axis
   While ismoving()
      Sleep 100
   Wend
   Code ("G0 G53 Y66."&(toolpos1)) 'move Y-axis
   While ismoving()
      Sleep 100
   Wend
End If
So I have fixed Y at 66 and then i get 0.*********xx from 1001 dro from my screen. So I can make minor adjustment on screen dro.
The question is, is it possible that my 1001 dro number change Y for +or-  number intered in1001 dro?    SO let say I have fixed Y66 from M6 macro, and I enter 10 in 1001 DRO, and that change actual position from Y66 to Y76.
Thank you
Gasper
