Hello Guest it is November 13, 2026, 08:05:39 PM
Author Topic: HELP NEEDED - Mach3 Software not loading.  (Read 9350 times)
« on: January 07, 2020, 07:34:12 PM »
Hello, I have a problem with the mach3 software. After I install mach3 (Without the parallel port driver because I am using a laptop) I try to run the program. It loads us and all I see is a blank screen. There is the toolbar at the top of the window, but the rest is white. I have tried loading the 1024.set file but nothing changes. I have tried reinstalling the program but that doesn't help either. If I could have assistance in this I would appreciate it.
My laptop is a Acer Aspire 3 A315-21-92FK
There is a screenshot attached of what the Mach3 screen looks like when I try to load it.
Also, when I load the program it gives me a error message, "Unable to open ProbeDiag.dat Error = 5" Any ideas?
I really appreciate the help, thanks.
-William Deacon
  •  9,377 9,377
Re: HELP NEEDED - Mach3 Software not loading.
« Reply #1 on: January 09, 2020, 12:56:48 AM »
Download the current version of Mach3 from here  https://www.machsupport.com/wp-content/uploads/2013/04/Mach3Version3.043.exe
then install that and see if it installs correctly.
« Reply #2 on: April 01, 2020, 03:47:35 PM »
Hi William
what is your monitor solution?
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #3 on: April 02, 2020, 01:31:33 AM »
Hi William
sorry, I meant resolution
Klaus
