Hello Guest it is October 24, 2026, 02:50:49 PM
Author Topic: how to handle double ended spindle  (Read 5068 times)
« on: January 04, 2020, 04:50:15 AM »
Anyone using a double ended spindle?  building a machine with crossed pair of double ended spindles and trying to figure out how to index the A axis 90 degrees for each tool on a "tool change".  From looking at the Fusion 360 sight the limited info I found is some machines handle it with an M code, others in the post.  Having touble getting the index in the post, but figured I could do a G52 shift in the M6 macro for each tool if I needed to.  Just wondering if anyone else out there has tackled this already.
