Hello Guest it is October 02, 2026, 07:48:18 PM
Author Topic: Mach3 macro  (Read 7633 times)
Mach3 macro
« on: December 23, 2019, 03:36:37 PM »
    i create 2 macro (M103 and M104) to power on and power off my wifi switch of my dust collector. If i execute them manually, everything is ok.
I will like to insert them on my aspire vectric post script. The problem is that it execute the command when it load the file, so my dust collector turn on and off when i load the file in mach3.
Post scrip is in attachment.
Do you guys have an idea why it is executing the command at the loading file.
Mike
Offline TPS
  •  2,627 2,627
Re: Mach3 macro
« Reply #1 on: December 24, 2019, 02:51:10 AM »
Config->General Config->Ignore M calls while loading
Re: Mach3 macro
« Reply #2 on: January 10, 2020, 07:54:59 PM »
Thanks, that was it.
