Hello Guest it is November 13, 2026, 01:00:00 PM
Author Topic: Plasma no small hole. ALSO THC ISSUE SOLVED  (Read 6801 times)
« on: December 22, 2019, 07:50:31 PM »
  Hi guys first thing I figured out my problem with thc. I had a EMI issue with my switching power supply. It effected my analog signal from the thc. Very hard problem to figure out when I replaced a digital and put the analog in the same location. Hope it helps someone else.
  All that said I am still having an issue with the table and hope you can help. It will not make a small arc like a 1/2" hole
I can cut circles and radius in parts but when I try to drill a hole it only makes a line half the diameter after the lead in.
any ideas would be awesome :D
