Hello Guest it is November 25, 2026, 10:22:03 AM
Author Topic: port error  (Read 7485 times)
port error
« on: December 16, 2019, 12:57:44 AM »
is some one can tell me why is this error?
and how solve it  without turn off pc?
thans
Re: port error
« Reply #1 on: December 16, 2019, 11:31:26 AM »
Is that inside Mach?
When does it show up?
What motion controller are you using?
Re: port error
« Reply #2 on: December 16, 2019, 11:47:05 AM »
pokeys
when run mach
Offline smurph
  •  1,575 1,575
Re: port error
« Reply #3 on: December 27, 2019, 02:51:07 PM »
As administrator, run:
netstat -a -b -n
That will tell you which program has port 50003 open.  Then you can kill the offending program in the task manager and re-start Mach.
Some programs use random ports when they startup and that will then cause a port conflict if they start up on a port that Mach uses.  The chances are that when restarting the PC, that program (whatever it may be) will not again use the same port range.
The real fix is to remove other programs that are not needed for a machine controller.
However, If you have to have a program that uses these port ranges, you can change the starting port that Mach uses by adding
BaseIpcPort=<some other starting port number>
to the Preferences section of the Machine.ini file in the profile's directory.
e.g.
[Preferences]
BaseIpcPort=45000
Steve
