Hello Guest it is October 24, 2026, 02:51:01 PM
Author Topic: MACH4 ShuttleXpress v2 inner wheel ONLY X JOG  (Read 6572 times)
« on: December 12, 2019, 12:22:34 PM »
Just now I´m migrating from MACH3 to 4.
I´ve installed the MACH4 ShuttleXpress plugin, and all seems that works OK.
I´configured the buttons to change JOG [AXIS] , and all works.
BUT....
The inner wheel only moves the X AXI. Always only move the X.
The Diagnostics and LOG of inner wheel seems OK.
Somebody can say where I´ve to configure it???
Thanks a lot in advance.
Offline dws
  •  24 24
Re: MACH4 ShuttleXpress v2 inner wheel ONLY X JOG
« Reply #1 on: December 13, 2019, 08:49:28 PM »
I am not sure if this info helps. This is for the Shuttle Pro V2 and not the Shuttle Xpress. This video shows how to configure the MPG for the inner wheel:
https://www.youtube.com/watch?v=lQmi6Q_iOAU
David
« Reply #2 on: December 14, 2019, 02:32:36 PM »
I've configured the MPG for the 3 axis , but only moves the X AXI.
With the outer wheel , I can select any AXI, if I have selected Y or Z, the outer moves the Y or Z, but the inner moves only the X.
It's very rare.
May be some problem with the PLUG IN ??
Where can I get the last plugin for MACH4 ???
« Reply #3 on: December 14, 2019, 02:42:15 PM »
OHHH!!! Thanks !
All solved.
I was assigning three MPGs.
All works OK.
Thanks a lot!!!!
