Hello Guest it is October 20, 2026, 04:03:19 PM
Author Topic: Get my shuttle pro working  (Read 11029 times)
Offline klmark
  •  107 107
« on: September 15, 2007, 10:51:02 AM »
Hi every one
I have just got my shuttle pro and I need help I know how to set buttons but I can't get her to jog with the outer ring I can do step movements with the inner ring but no luck with the jog   Any help would be appreciated      klmark
Offline Greolt
  •  956 956
Re: Get my shuttle pro working
« Reply #1 on: September 15, 2007, 05:44:58 PM »
I think it is a version issue.
If you are using the latest version of Mach then redownload the plugin.
If an older version then you might need an older version of plugin.
I installed the latest version of plugin (with Mach 2.4) and the outer ring would not work
so I reverted to an older plugin and Hey Presto all working.
Greg
Offline klmark
  •  107 107
« Reply #2 on: September 17, 2007, 08:25:34 AM »
Thanks I will try in a couple days I will be out of the shop
    klmark
Offline klmark
  •  107 107
« Reply #3 on: September 21, 2007, 09:56:42 AM »
Hey It works great Thanks for the Help
         klmark
