Hello
Guest
it is
October 24, 2026, 06:29:12 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
% axis movement in MACH4
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: % axis movement in MACH4 (Read 7608 times)
chuck767
114
on:
December 10, 2019, 11:25:28 AM »
In MACH 3, a part could be built smaller or larger than the designed part by changing the percentage of the axis movement.
How is this done in MACH 4?
ie, in MACH 3, a part could be built half size by changing X, Y, and Z to 50%
Chuck
Logged
joeaverage
7,663
Re: % axis movement in MACH4
Reply #1 on:
December 10, 2019, 11:53:34 AM »
that feature is a property of Gcode programming, any good CNC software solution will do it including Mach3 AND Mach4.
It called G51 scaling. Page 42 of the Mach4 Mill Gcode Programming manual in the Help Docs folder.
Logged
chuck767
114
Reply #2 on:
December 10, 2019, 12:37:53 PM »
Thanks Craig,
I was hoping MACH4 had the same % features as MACH 3.
I have a small tabletop mill at the house, 12 inch X travel. I use that mill to test programs I run on my larger mill and laser just to make sure everything is working right. It's very convenient to simply change the percentage MACH3 and use the exact same G code on the larger machines run at 100%
Chuck
Logged
joeaverage
7,663
Reply #3 on:
December 10, 2019, 05:50:31 PM »
it does. Code g51 in MDI panel and your done. If you want to attach it to a button or a slider you can do that too...
Logged
chuck767
114
Reply #4 on:
December 11, 2019, 08:16:41 AM »
Thanks Craig, I was not aware of G51
Logged
Print
Pages:
1
Go Up
« previous
next »
