Hello Guest it is November 13, 2026, 09:54:07 AM
Author Topic: Problem with Mach3 and nvum V2 usb  (Read 10667 times)
« on: December 10, 2019, 09:34:38 AM »
Hi.
Can`t seem to get the controller connected to the mach 3 on my laptop.
In mach3 it only says USB Device Connected.
The plugin for the nvum has beed placed in the plugin folder, and it`s been selected at mach 3 startup, but no Connection.
Anyone know what the issue could be?
My pc is running win10
Re: Problem with Mach3 and nvum V2 usb
« Reply #1 on: December 10, 2019, 09:51:28 AM »
I had directions to place the dll in the plugin folder as well as the main mach3 folder - but I'm using win 7 pro - it may be worth a try if you didn't - also my dll that I'm using is a 3.o version from the novusun web site
« Reply #2 on: December 10, 2019, 09:59:08 AM »
Hi!
Already tried that, but not working, but thanks for the tip:)
« Reply #3 on: December 11, 2019, 03:06:40 AM »
the company that makes NVUM controllers peddles pirate copies of Mach3. You will get no help unless you have
a genuine Mach3 license.
