Hello Guest it is November 25, 2026, 06:04:34 AM
Author Topic: Activate custom output pin via machine enable button  (Read 8428 times)
« on: November 28, 2019, 09:24:38 PM »
Hi everyone, first post.
I am running Mach 4 with ethernet smooth stepper.
Basically, I want to change the colors of a LCD strip based on the machine status (motors enabled, cycle started, etc.)
In my ESS configuration, I have set output 49 to port3 pin 9
I managed to create a button that pulls the pin high when I press it.
What I want is for it to pull high when I press the "Enable" button (the one that enables machine controls), and pull it low when I press disable
same for spindle start and cycle start
where can I find the script that this button calls
what lines do I need to add
So far I have only found scripts regarding the screen (LUA)
Thanks!
Re: Activate custom output pin via machine enable button
« Reply #1 on: November 28, 2019, 10:15:46 PM »
I think what you want is to copy the machine enable state to your output. I would just use the PMC Editor (Configure > PMC) for that.
See attached image. This will run every 10 ms and copy the machine enabled signal to your output 49.
To do this, you can do this:
1. In PMC Window, click Settings > Code generator and select LUA
2. Instruction > Insert Contact
3. Double Click newly created contact and configure:
    - Source: Core Output
    - Name: machineEnabled
    - Device: Signal
    - Object: Machine Enabled
    Accept with click on ok.
4. In PMC Window move the cursor behind your newly created contact by clicking there
5. Instruction > Insert Coil
6. Double Click newly created coil and configure:
    - Name: output49
    - Device: Signal
    - Object: Output #49
7. Click File save and save the pmc to C:\Mach4Hobby\Pmc
8. Click Generate and save the lua script there too
Then do what is described in this video at 4:47 to enable the PMC script:
https://youtu.be/jVhH9qyjjf0?t=287
It should work then. Add in PMC another rung for cycle start and your other output. Dont forget to hit Generate again.
« Last Edit: November 28, 2019, 10:30:20 PM by brandonb »
« Reply #2 on: November 28, 2019, 10:41:54 PM »
You could also just use the Output Mapping of Machine Enabled directly to your Port 3 / Pin 9. This would work out of the box but would only work if you do not already got a pin mapping configured there.
To do this just click Configure > Control and select the tab "Output Signals". Scroll down until you find "Machine Enabled" signal and configure it.
Mach4 has many of these prebuild signals that one should use.
« Reply #3 on: November 28, 2019, 11:01:40 PM »
Setting it from the control--> output works like a charm.
But, I get this error when trying the PMC way.
It works just fine in the live simulation...
« Last Edit: November 28, 2019, 11:16:19 PM by SIAB Studio »
« Reply #4 on: November 28, 2019, 11:43:15 PM »
Went to said line that the error code stipulated. Somehow i figured my problem.
I had saved my MPC as LED control. Didn't like the space there. Saved it again to LEDcontrol. Compiled, boom. Works.
Thanks to everyone!
