Hello Guest it is November 25, 2026, 06:04:36 AM
Author Topic: How to process analog inputs  (Read 8043 times)
« on: November 28, 2019, 05:40:17 PM »
I have some analog inputs (potentiometers) which are supposed to control the feed and spindle rate. How would one script that in Mach 4? What would be the proper way to access analog values? There does not seem to be any analog input related page in the configuration menu. My controller is a CSMIO which comes with analog inputs.
I already have tried the awesome lua features in Mach 4 to program my toolchanger. But this consist of mainly boolean IO operations.
Best regards
brandon
Re: How to process analog inputs
« Reply #1 on: November 28, 2019, 06:57:57 PM »
Mach cannot in itself handle analogue values, the motion controller can.
If the CSMIO works similarly to other controllers the analogue value is converted to a digital number and that number is stored
in a register within Mach, but the register is 'owned' by the CSMIO plugin.
Consult the CSMIO plugin documentation and you should be able to find the name and path of the register used.
« Reply #2 on: November 28, 2019, 07:58:13 PM »
Thanks for your help Craig,
What you say makes sense. But i cannot find any mention of registers in the manual of the controller.
Is there somehow a way to list all registers in Mach? Maybe I can spot the CSMIO Registers then.
Best regards
Brandon
« Reply #3 on: November 28, 2019, 08:33:07 PM »
Yes, with Mach4 open click the <Diagnostics> tab, select Regfile and that will display ALL of  Machs registers.
« Reply #4 on: November 28, 2019, 10:09:08 PM »
Awesome. Thank you very much Craig.
It works now. The analog values are being picked up and stored to the properties of Mach 4. I use the following code to set the jog rate:
Code: [Select]
local hReg, rc, val;
hReg, rc = mc.mcRegGetHandle(inst, "CSMIO-IP/Analog Input 0");
val, rc = mc.mcRegGetValue(hReg);
-- covert 0..10 V to 0..100 %
val = val * 10.0;
mc.mcJogSetRate(inst, mc.X_AXIS, val);
mc.mcJogSetRate(inst, mc.Y_AXIS, val);
mc.mcJogSetRate(inst, mc.Z_AXIS, val);
mc.mcJogSetRate(inst, mc.A_AXIS, val);
mc.mcJogSetRate(inst, mc.B_AXIS, val);
mc.mcJogSetRate(inst, mc.C_AXIS, val);
scr.SetProperty("droJogRate", "Value", string.format (val))
Best regards
Brandon
