Hello Guest it is September 30, 2026, 01:38:40 AM
Author Topic: How to create a simple toggle button?  (Read 25866 times)
« on: November 26, 2019, 02:04:49 PM »
Can anyone explain how to create a simple toggle button (code/script) that I can use to turn on/off an output or trigger a Modbus command?  Thanks much for any replies/guidance/links/videos/etc.
Offline TPS
  •  2,627 2,627
Re: How to create a simple toggle button?
« Reply #1 on: November 29, 2019, 02:24:46 PM »
If IsActive(OUTPUT1) Then
    DeactivateSignal (OUTPUT1)
Else
    ActivateSignal (OUTPUT1)
End If
« Reply #2 on: December 14, 2019, 04:33:43 PM »
HEY!! Just saw this (don't know why the notification via email isn't working??) but THANK YOU VERY MUCH SIR!
« Reply #3 on: December 14, 2019, 05:03:38 PM »
OK, I just tried it....  Output is activated as expected but will not Deactivate.    I'm using Output 6 and copied your script only changing the "1" to a "6".  Any ideas what could be Wonky??  THANK YOU!!!
Offline TPS
  •  2,627 2,627
« Reply #4 on: December 15, 2019, 03:03:22 AM »
for Output 6 try this:
Code: [Select]
If GetOEMLed(79) Then
    DeactivateSignal (OUTPUT6)
Else
    ActivateSignal (OUTPUT6)
End If
« Reply #5 on: February 19, 2020, 03:12:29 PM »
Worked like a Charm!! THANK YOU !!!!!
« Reply #6 on: February 19, 2020, 03:50:01 PM »
NEXT QUESTION!!!  What you explained works GREAT for Outputs already a part of the MACH3 architecture BUT, what if you run out of MACH3 Outputs and just want to turn on/off more devices via MODBUS/PLC.
For example, I want to turn on/off the Air Compressor in my shop by pushing a button on MACH3 Screen.
Simply Put... in the example below... what do I enter to replace the OUTPUT1 identifier so it will be recognized by MODBUS instructions?
Else
THANKS AGAIN SO VERY MUCH FOR YOUR HELP!
Offline TPS
  •  2,627 2,627
« Reply #7 on: February 20, 2020, 12:31:37 AM »
should be
SetOutBit(BuffIndex, BitNumber)
ReSetOutBit(BuffIndex, BitNumber)
but never worked with modbus
« Reply #8 on: March 13, 2020, 05:22:21 PM »
Thanks for your reply.  Sorry if this is a stupid question but....  How do I know the BUFFINDEX address?  are you referring to the MODBUS Address?  Not clear on this.  Perhaps and example with some sample data would be helpful if you wouldn't mind??
THANK YOU!
Offline TPS
  •  2,627 2,627
« Reply #9 on: March 14, 2020, 02:34:05 AM »
as written i never worked with modbus,
but here
http://www.machsupport.com/videos/
is a Video witch explains modbus a Little bit.
