Hello Guest it is November 07, 2026, 10:27:25 AM
Author Topic: Mach3 Configuration problem with machine coord`s and soft limit  (Read 19546 times)
« on: November 26, 2019, 05:23:11 AM »
Hi, I hope you can help me with this problem, since I bought the machine I have not been able to use it correctly, nothing I do puts the coordinates of the machine at 0, and I have never been able to configure the soft limit.
This is the hardware used by my machine and the machine model:
NVUM CNC Controller
TB6600 Stepper Driver
CNC Workbee 1000mm x 750mm
no switch limit installet
Windows-10
I send you a screenshot of my current configuration to see if anyone sees any errors that I can correct and thus be able to configure my machine correctly
Re: Mach3 Configuration problem with machine coord`s and soft limit
« Reply #1 on: November 26, 2019, 05:27:39 AM »
this its the rest of the picture
  •  9,375 9,375
« Reply #2 on: November 26, 2019, 06:04:24 AM »
Hi Eduardo,
Unfortunately Novusun is one of the businesses listed in our Hall of Shame for Mach3 Licence violation. As a result this forum does not support assistance with any of it's products.
This thread refers;  https://www.machsupport.com/forum/index.php?topic=24331.msg171954#msg171954
« Last Edit: November 26, 2019, 06:16:17 AM by Tweakie.CNC »
« Reply #3 on: November 26, 2019, 06:54:55 AM »
Thanks for the reply Tweakie as I took some time and I was about to post some good help for this user.
Eduardo,
Consider doing what is right since it has many benefits!
