Hello Guest it is November 26, 2026, 08:26:45 AM
Author Topic: "Go To WorkZero" doesn't lift up Z axis.  (Read 15029 times)
« on: November 18, 2019, 11:15:52 PM »
Hi
I'm changing a MACH4 computer(upgrading thw S/W too from MACH4 older version to 4388), and confront some problems. ;(
I clicked on "Go To WorkZero" on the default screen.
I thought it would lift up the Z axis first, but the machine just moved its X and Y axis only.
So I opened the screen editor and open the script.
I found it did have Z axis movement in the script.
(I deleted "\nG00 Z0" at the end.)
GoToWorkZero()
--local inst = mc.mcGetInstance()
--mc.mcCntlMdiExecute(inst, "G00 G53 Z0\nG00 X0 Y0 A0")
Why the machine doesn't move Z axis?
Re: "Go To WorkZero" doesn't lift up Z axis.
« Reply #1 on: November 18, 2019, 11:28:01 PM »
why its have the double minus at the line head?
is it just mistake when copy? or its also on script?
« Reply #2 on: November 18, 2019, 11:50:58 PM »
It is as is in the script. I copied it.
I didn't make any change with "--"
« Reply #3 on: November 18, 2019, 11:53:59 PM »
Do you know the meaning of --?
« Reply #4 on: November 19, 2019, 12:20:59 AM »
in Lua the '--' signals that ALL text thereafter, on the same line is a comment.
This line:
does absolutely nothing, Lua/Mach ignores it as a comment. If you remove the '--' then the code3 becomes active.
« Reply #5 on: November 19, 2019, 12:39:00 AM »
I don't know about coding.... T.T
Craig told me "--"means comment. lol~
« Reply #6 on: November 19, 2019, 12:39:25 AM »
This line:
Thank you Craig, now I think I know what's wrong here. ;)
« Reply #7 on: November 19, 2019, 12:46:54 AM »
This line:
I removed "--" but Z axis still doesn't move...
GoToWorkZero()
mc.mcCntlMdiExecute(inst, "G00 G53 Z0\nG00 X0 Y0")
What would be wrong? ;(
Offline dws
  •  24 24
« Reply #8 on: November 19, 2019, 07:25:56 AM »
I am not sure what it is; but, I had a similar problem with 4338. I switched to version 4322. All is well now.
« Last Edit: November 19, 2019, 07:28:01 AM by dws »
David
« Reply #9 on: January 20, 2020, 02:43:03 PM »
Has this ever been resolved?
I am getting the same results in my newly installed Mach4 build 3200, GoToWork Zero moves all axis except Z
I tried Mill and Lathe profiles, same results.
