Hello Guest it is October 21, 2026, 11:40:42 AM
Author Topic: How to inspect a MacOS executable file (Mach-O)?  (Read 7882 times)
« on: November 16, 2019, 12:40:15 AM »
How to see some basic information about a MacOS binary file, specifically what was used to build it, which frameworks it is linked against and what system calls it is using?
I tried
Code: [Select]
nm and
Code: [Select]
otool -L but their output is only partially useful.
For example, what would indicate that a binary was built with xcode or golang compiler?
  •  9,374 9,374
Re: How to inspect a MacOS executable file (Mach-O)?
« Reply #1 on: November 16, 2019, 01:32:49 AM »
Hi Isabella85,
Where are you finding the MacOS binary file to which you refer ?
