Hello Guest it is November 23, 2026, 07:01:08 PM
Author Topic: Where is Auto tool zero script saved?  (Read 9653 times)
Offline kak
  •  81 81
« on: November 09, 2019, 12:33:26 PM »
Hello.
My Windows XP stopped working after power failure, so I connected the HDD as a slave to another computer.
I want to back up some things.
I have copied the xml file, but cannot find the auto tool zero macro.
It's just a text file inserted in VB Script Editor, but I can't start Mach3 without Windows, to see the script.
Do you know if I can find it somewhere in Mach3 folder?
Re: Where is Auto tool zero script saved?
« Reply #1 on: November 09, 2019, 08:49:28 PM »
C:\Mach3\macros\Mach3Mill   <-- or whatever profile name you've used
The file name is      HiddenScript.m1s
but for safety I'd copy the whole folder of macros\Mach3Mill   <-- or whatever profile name you've used
  •  9,378 9,378
« Reply #2 on: November 10, 2019, 06:02:58 AM »
The Auto Tool Zero script is saved within the relevant button in the Screen set you are using (typically 1024.set).
(the file HiddenScript.m1s is only a temporary store for the last macro / script used).
Offline kak
  •  81 81
« Reply #3 on: November 10, 2019, 03:23:43 PM »
Thank you very much :-)
